I have a 91 NA w/150K miles. I'm going with Tokico Illumina struts and Eibach Sportline springs. I'm also replacing the bump stops with 93 bump stops, which are a bit shorter.
Just looking for help with a few questions:
I wasn't planning on replacing the front ball joints. What about the strut mounts (strut tops)? I'd prefer not to spend more $$$ on these, assuming the existing ones are OK, but considering my mileage, does anyone think that's a bad move in the long run with either of these?
Also, should I have crash bolts installed at the same time, or would an alignment shop install those as part of the camber and toe dial-in. Lastly, is a camber/toe adjustment part of an overall wheel alignment, or is that a seperate service (and thus, more $$$).
I guess I could have called this thread "Alignment Idiot" just as well, huh?
TIA for any input.
