BOV REmoval - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2005, 04:18 PM   #1 (permalink)
beaten by Fujiwara panda
nato1012's Avatar
View nato1012's Photo Gallery
BOV REmoval & Denso Iridium Plugs
ey everyone...i just purchased the factory BOV and Pipe from Ebay..its coming off of a 1996JDM Spec mr2. I currently have an HKS SSQV BOV. Is there anything within that swap that I should look out for? Would it affect the other mods that were done to the car.
I believe the EGR on my car was disabled, Cat was hollowed, K&N Intake, Borla Exhaust. Im just mindful of the jdm bov affects on the current set up. thanks
http://www.cardomain.com/memberpage/764918/2
NATO1012 New Jersey
MR2 Turbo Super white
nato1012 is offline   Reply With Quote
Old 02-22-2005, 05:52 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
If you don't have a 3rd gen motor I don't think it will fit right. I'm not sure what the difference is..... but I know the 3rd gen and 2nd gen have different IC pipes. If you are not using the pipe and just using the BOV.... I think you will be okay. Make sure everything is there.... including the vsv.
Your car should be a little quicker to respond and the a/f's should clear up a bit.
Old 02-28-2005, 12:17 PM   #3 (permalink)
nato1012's Avatar
factory set up referrence
Does anyone have a scanned descritpion of the factory layout of the OEM BOV. I just got it in and I dont have a referrence to go by. The HKS SSQ BOV will be removed. I just want to make sure all the propper connections are made. Finally more efficient gas consumption and better response.
Thanks
NATO1012 New Jersey
Old 02-28-2005, 12:55 PM   #4 (permalink)
Piddy's Avatar
This should help.... http://mr2.noegruts.com/engine/engine01.jpg
Old 02-28-2005, 01:02 PM   #5 (permalink)
nato1012's Avatar
Thanks man...it will definitely help..cant wait to put that sucker on...
NATO1012 New Jersey
Old 03-02-2005, 12:00 PM   #6 (permalink)
nato1012's Avatar
ey everyone..i just had another question about Denso Iridium Plugs. Assuming that there is an imbalance in air fuel mixture as a result of the BOV **HKS SSQV** venting to atmosphere, would these plugs correct that imbalance of air fuel ratio. that is the current plug set up in my car. **along with the TRD Wires** How would the car be affected if the Stock BOV as installed to go along with the plugs and wires.
NATO1012 New Jersey
Old 03-02-2005, 04:35 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $996975
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I don't see how any plug could correct an air/fuel ratio...
The Jedi Speeder at CarDomain
Old 03-02-2005, 05:58 PM   #8 (permalink)
nato1012's Avatar
Well im just thinking not all plugs are the same. The burn factor maybe more on Iridium plugs..i just figured it may burn the excess fuel dumped to burn the air that is vented out from the AF BOV.
NATO1012 New Jersey
Old 03-02-2005, 10:57 PM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
possibly, but to burn more fuel it takes more air. it's a vicious circle.
Old 03-03-2005, 09:05 AM   #10 (permalink)
nato1012's Avatar
ahh i see....this is one of the reasons i dont like buying a tampered car. id rather mod it myself. thanks man
NATO1012 New Jersey
Old 03-03-2005, 01:29 PM   #11 (permalink)
View wingmanlg's Photo Gallery
Im not very familiar with the hls bov. Why would you want to remove it?
wingmanlg is offline   Reply With Quote
Old 03-03-2005, 03:32 PM   #12 (permalink)
nato1012's Avatar
Im running too rich plus..there's some proof that the oem responds faster and is more efficient.
NATO1012 New Jersey
Old 03-03-2005, 10:09 PM   #13 (permalink)
oh ok, thanx for the info...
Old 03-03-2005, 10:28 PM   #14 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
The aftermarket vent to atmosphere BOV's do make your engine run a lttle richer. But better rich than lean. I am using a Turbo XS BOV and I do like it, but i have been thinking about going back to the stock one. If the Turbo XS BOV ever fails, I WILL put the OEM bypass back on and keep it that way. best thing to do is keep your engine tuned-plugs,cap, rotor and wires in good condition...
Old 03-03-2005, 10:38 PM   #15 (permalink)
nato1012's Avatar
Yup ill definitely fo that.. thanks..it will take some getting used to not hearing that thing go off.
NATO1012 New Jersey
