gutting cat. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2005, 11:04 PM   #1 (permalink)
victor91mr2
victor91mr2's Avatar
View victor91mr2's Photo Gallery
gutting cat.
has anyone gutted their cat., if so how did you go about doing so. i want to gut my cat because i dont really want to spend 300$ on a downpipe. thanks
victor91mr2 is offline   Reply With Quote
Old 02-24-2005, 11:15 PM   #2 (permalink)
View T3vzGfeF's Photo Gallery
well my friend and i used a heavy duty pry bar and a hammer to gutt out my cat, until we saw a crack in the middle part of the cat...so then i ordered a test pipe on ebay...it replaces the stock cat...
check it out--> http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
T3vzGfeF is offline   Reply With Quote
Old 02-25-2005, 12:26 AM   #3 (permalink)
Lead-Foot
S92GT's Avatar
View S92GT's Photo Gallery
humm, what all does this do for performance, where are the gains on the powerband, where can you feel it the most?
S92GT is offline   Reply With Quote
Old 02-25-2005, 05:48 AM   #4 (permalink)
View vtsuckah's Photo Gallery
It's not worthe the time and effort, not to mention your car will reak of sour ass.
vtsuckah is offline   Reply With Quote
Old 02-25-2005, 08:39 AM   #5 (permalink)
Gameroom cash: $147537
A gutted cat will acturally hurt power.
If you look at the thing closely, it got bigger size then your exhaust pipe. With the stuff inside, it got same x-section area as the pipe so exhaust flow with same velocity and pressure. Removing the ceramic inside the cat will increase x-section area. When gas go from a small x-section to large, it slow down, then it need to squeeze down again to exit the gutted cat into small pipe. The expansion and compression require energy which increase back pressure and reduce exhaust velocity.
Either buy a highflow cat or replace it with a pipe.
Old 02-25-2005, 09:11 AM   #6 (permalink)
Pineapple is right, there is no gains from doing so. I could go into the whole thermodynamic explanation, but pineapple's will do.
Old 02-25-2005, 10:06 AM   #7 (permalink)
Lead-Foot
S92GT's Avatar
I didn't mean gutting it, I meant the test pipe, getting rid of the cat all the way, how much is that?
Old 02-25-2005, 10:20 AM   #8 (permalink)
A few pnoy. Cat are not that restrictive. Get a 3S-GE header, stock one are good. That'll remove your stock cat. You can put one back after the header or leave it that way.
I've forgotten all already.
Old 02-25-2005, 12:08 PM   #9 (permalink)
Lead-Foot
S92GT's Avatar
well, rockin' a 5s I can use all the HP available
Old 02-25-2005, 12:15 PM   #10 (permalink)
haha still not enough to make a diff. A header and cams will give you the most bang for your buck.
Old 02-25-2005, 02:52 PM   #11 (permalink)
You don't really want to free flow everything. 5S is about torque, not HP. Get a 4-2-1 header. 3S-GE one will do, even stock one is 4-2-1.
Old 02-25-2005, 04:50 PM   #12 (permalink)
well i have a video clip of my exhaust with the test pipe revving it up...but i need a host...
Old 02-25-2005, 11:28 PM   #13 (permalink)
victor91mr2
you all may think that there is no hp gains but when you think about it,
back- pressure isnt exactly what you want with a turbo system(3SGTE not 3SGE). That cat. is completely plugged, its like a sponge. Also this is an "In-expensive" way to free my exhaust of any restrictions wich was the goal to begin with, with this mod i may lose some torque(minimal), but my spool time and repsonsiveness with be enhanced. Its not like im gutting the cat while using factory exhaust, im using the 3in APEXi N1.
Old 02-25-2005, 11:50 PM   #14 (permalink)
View karugs's Photo Gallery
I thought you were going to slice your pet cat up
karugs is offline   Reply With Quote
Old 02-26-2005, 03:00 AM   #15 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
I'm glad someone mentioned the smell! my rx7 had a gutted cat, and it smelled like sulfur... aka "sour ass".... but it made that rotary scream.... once I get my 5sfe turbo engine installed I will be running 2 1\2" from the turbo to the tips.... no restrictions, and minimal bends....
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
