Hi,
I'm new to this forum but not Toyota's. I want to put a ZEX 75hp Wet Nitrous Kit on a MK1 MR2. Will I need to upgrade the fuel system at all like better fuel rail, fuel pump, injectors, fuel pressure regulator etc? If so what specific parts do you guys recomend. Here's the setup that I came up with. Give me your advice.
- ZEX Wet Nitrous Kit
http://andysautosport.com/products.p...20Oxide%20Kits
-Weapon R Fuel Pressure Regulator
http://andysautosport.com/products.p...e%20Regulators
-Weapon R Billet Aluminum Fuel Rail Adapter, will this thing be any better than the stock piece or is it all for show?
http://www.eautoworks.com/html/ORD-1-1-1-24135.cfm
-Better fuel pump if needed.
Anthony
P.S. With a 75 shot, will a better than stock ignition system be needed? If so, what do you recommend?
