Intercooler fan... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2005, 12:07 PM   #1 (permalink)
aka "Downforce"
View Strat42586's Photo Gallery
Intercooler fan...
I read recently on a post that it's possible to clip a wire on the stock intercooler fan that would cause the fan to always stay on, thus helping to keep the temp down at all times. Is this actually beneficial and worth it? And if so, which wire is it?
Strat42586 is offline   Reply With Quote
Old 03-21-2005, 12:52 PM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
You do not need to "clip" anything.
There is sensor on the engine lid .... simply unplug it and the fan runs all the time.
This does help to keep engine bay temps down.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 03-21-2005, 01:31 PM   #3 (permalink)
aka "Downforce"
Oh wow, that's simple. Thanks man.
Old 03-21-2005, 01:43 PM   #4 (permalink)
I love Cin
You have to love simple, free mods
Old 03-21-2005, 05:49 PM   #5 (permalink)
aka "Downforce"
Any other free mods worth doing that I need to know about?
Old 03-21-2005, 08:37 PM   #6 (permalink)
I love Cin
Well, you can eliminate fuel cut fo free
Old 03-21-2005, 09:30 PM   #7 (permalink)
View carcatz's Photo Gallery
could you also put in a toggle in series and use it as an option??
carcatz is offline   Reply With Quote
Old 03-22-2005, 05:17 AM   #8 (permalink)
I love Cin
Yes. That is how I have it set up.
What you are actually "toggling" is not the FAN off/on, but rather the SENSOR off/on.
Toggle one = fans run all the time
Toggle two = sensors on, so fans come on when it is hot enough
Old 03-22-2005, 06:50 AM   #9 (permalink)
you have 1 switch correct normally open and normally closed?
Old 03-22-2005, 07:23 AM   #10 (permalink)
I love Cin
Correct.
Opening the switch turns OFF the sensor which turns on the fans.
Closing the switch turns the ON the switch which controls the fans (they come on when it gets hot enough).
Old 03-22-2005, 07:42 AM   #11 (permalink)
yeah when you said toggle1 and toggle2 I thought you have it set up with two switches!
Old 03-22-2005, 09:33 AM   #12 (permalink)
I love Cin
Sorry ... just refering to toggling one way or the other on the same swtich
Old 06-11-2005, 02:11 PM   #13 (permalink)
View 1qckmr2's Photo Gallery
so how would you go about eliminating fuel cut off? i have a 2.5 in downpipe and some other mods and a manual boost controller but havent installed it. boost settings are different in third on up so if i got rid of fuel cut, could i use the manual controller?
1qckmr2 is offline   Reply With Quote
Old 06-11-2005, 05:33 PM   #14 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Plug the hose that leads to your 'Boost Pressure Sensor' in the rear right corner of your engine bay. The hose goes from the intake plentum to the pressure sensor.... just plug it with a screw.
