tranny gear grind - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2005, 11:54 PM   #1 (permalink)
oooo....shiny...
View MR2Enthuze's Photo Gallery
tranny gear grind
hey all, ive been having trouble wit my 91 NA mr2's tranny. wen ever i put it into reverse with the clutch fully depressed it grinds as i shift it. any one kno the source of this problem??
MR2Enthuze is offline   Reply With Quote
Old 03-28-2005, 11:57 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
No problem...
Reverse has no syncros. Shift into first and drive forward just enough for it to engage.... then put it into reverse. Should be smooth as butta!!!
Old 03-29-2005, 12:02 AM   #3 (permalink)
oooo....shiny...
WOAH jus tried it, just tried it and works perfectly thanx alot!
Old 03-29-2005, 02:22 AM   #4 (permalink)
View 91MR2quickNA's Photo Gallery
You might wanna adjust your pushrod play in the clutch pedal. It shouldn't grind at all. The BGB actually uses reverse to test your clutch pedal engagement point because it doesn't have a synchro. Even if the above solution did work, check your pushrod play anyway and adjust if necessary. It might improve your overall shift quality.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 03-29-2005, 08:03 AM   #5 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
if the MkII has the same 'square' bushing in the shifter linkages, sometimes, turning it 90* will improve shifting a bunch. so do Speed SOurce brass bushings.
ToyotaTechGeek is offline   Reply With Quote
Old 04-02-2005, 10:12 AM   #6 (permalink)
View MitchB's Photo Gallery
Indeed. And bleed it while you are at it. That usually helps as well.
Yes, it's an N/A. It IS a 3.0 liter V6 though. Does that matter?
MitchB is offline   Reply With Quote
