speedometer not workin - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2005, 03:44 AM   #1 (permalink)
View lil' zipper's Photo Gallery
I just got this car and the speedometer does not work. Everything else works like the tach fuel etc. I took the bezel out and the cable is connected. I checked the tranny and same thing, connected. I'm hoping it's a sensor of some kind because to change that wire looks like a pain in the rear. can anyone help?
lil' zipper is offline   Reply With Quote
Old 03-30-2005, 05:14 AM   #2 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
What year MR2 do you have?
'93 and up have electronic speed sensor. It's not that hard to replace.
Pre '93 has the mechanical spinning speedo cable. The rear one isn't too hard to replace, but the front can be a pain. If you have a pre '93, pull the cable off the tranny and check if the gear is spinning. If it is, it's one of the speedo cables. If it isn't, you probably need to replace the gear in the tranny. This happens quite often on the '91 and '92 MR2's.
Hope I could help.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 03-30-2005, 03:27 PM   #3 (permalink)
i'l try that and let you know what happens. thanx
Old 03-30-2005, 03:30 PM   #4 (permalink)
its a 92
Old 03-30-2005, 04:39 PM   #5 (permalink)
Rockin the STi
View onehotcamry's Photo Gallery
i've noticed that when looking for mr2's for sale, a lot of them had a problem w/ the speedo cable not working. Atleast 2 or 3 of them have been like this so that could and "probably" is your problem. Let us know how it goes
04 WRB STi - Stg. 2
93 White Mr2T - 263 rwhp @ 10psi
95 Black Mr2T - TKO exhaust
04 Suzuki GSX-R600
onehotcamry is offline   Reply With Quote
Old 03-31-2005, 03:59 AM   #6 (permalink)
Ok. I took the cable out and started to toy around with the cable and the base or sensor, and when I started driving, it worked somehow BUT, all is not done because the needle bounces. It does not look like it's stable, so, when I wake up later 2day, I'm gonna unscrew it and screw it back in as tight as I could to see if that will do it. If not than I guess I'll be reading from you again.
Old 03-31-2005, 05:15 AM   #7 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
It is fairly common for the 91/92s to breakthe gear inside the tranny.
A word of warning on buying used MR2s with broken speedos ... you will not know how many miles are really on the car.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 03-31-2005, 01:36 PM   #8 (permalink)
My odometer reads 103,xxx. Which I don't mind. Thats pretty good 4 a 92.
Old 03-31-2005, 07:05 PM   #9 (permalink)
Gameroom cash: $134355
that goes for any car with a mechanically driven speedometer..... the odometer will also not register.... my corolla's original gauges have about 400 unaccounted miles on them
Old 03-31-2005, 07:10 PM   #10 (permalink)
Ok. Does anyone know where I could get that part, and how much am I aprox. looking @?
Old 03-31-2005, 09:47 PM   #11 (permalink)
4DMR2t's Avatar
The part itself is relatively inexpensive, I think. It's pulling the tranny and breaking it apart that's the pain in the butt. At this point, you might as well rebuild it. I ran into this same problem a while back. Instead, I just bought an LSD tranny!
A lot less headache, and did I mention it's LSD? You'll thank me later!
Old 04-01-2005, 03:19 AM   #12 (permalink)
That sounds like fun . Well I guess I'll do that when I get my hands on a stage 2 clutch. Wweeeeeeee
Old 04-01-2005, 12:38 PM   #13 (permalink)
you can't get the gear out in a mk2? they have the e150 tranny, correct? i would assume they have the speedo drive gear in the same location as the e51 (sc mk1 tranny),..... it's a pain in the butt to get out, but you can (the gear and drive piece comes apart in 2 pieces and will slide out)
Old 04-01-2005, 03:46 PM   #14 (permalink)
But the tranny has 2 b out or can I do it without all that hassle?
Old 05-20-2005, 01:04 PM   #15 (permalink)
helpful
View lioneljones2001's Photo Gallery
go to this web site to get the cable with out rebuilding the tranny. stephenmason.com/cars/mr2speedo.html
lioneljones2001 is offline   Reply With Quote
