B-Pipe removal... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2005, 06:30 PM   #1 (permalink)
aka "Downforce"
View Strat42586's Photo Gallery
B-Pipe removal...
I read that you can't take off the stock b-pipe without basically putting the car on a lift. Is there really no other way to remove the stock downpipe, b pipe and muffler without using a lift?
Strat42586 is offline   Reply With Quote
Old 04-02-2005, 02:36 AM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Yea... there is. I did an entire turbo swap in my garage.... just takes a little patience to get that b-pipe off.
You have to jack the back of your car up REALLLLLY high to get the bpipe to clear the ground. Took me about an hour to figure it out.... but.... if you look at the BGB... there are some good directions.
Old 04-02-2005, 01:03 PM   #3 (permalink)
aka "Downforce"
I checked the BGB, and all aI could find was this page: http://www.mr2-tech.com/bgb/mechanic...ust_system.htm But that doesn't have directions on how to remove the exhaust system, just breaks down the different components of the exhaust. What section would it be in?
Old 04-02-2005, 01:53 PM   #4 (permalink)
L J
L J's Avatar
View L J's Photo Gallery
well i couldnt lift my car high enough at all to take the b-pipe off so i just cut it like most people do...
L J is offline   Reply With Quote
Old 04-03-2005, 05:41 AM   #5 (permalink)
View OEMonkey's Photo Gallery
or, if you can't lift the car high enough, you can just lower the xmember.
OEMonkey is offline   Reply With Quote
Old 04-03-2005, 01:15 PM   #6 (permalink)
Piddy's Avatar
Yea.... its not in the exhaust section. I'll check when I get home for you. It was in a weird spot.
Old 04-04-2005, 01:20 AM   #7 (permalink)
L J
L J's Avatar
i was about to do that but i'd figured it would take longer than cutting...
