i assume you're asking about 3 rib block vs. 7 rib.
what caused you to throw the rod?
if you are throwing rods, it might not be 'caused' by the three rib. i'd look at oiling or ignition/fuel, etc...
i don't see anything in your list of build-up that would 'cause' a 3 rib to fail. most problems are caused by the nut behind the wheel. also maybe the engine builder. if you are assembling this thing now, wouldn't it be wise to make the decision as to whether or not you will throw boost into the mix? seems to me the smart way to go seeing how compression becomes a factor.
