need help with Air/Fuel Ratio Guage - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2005, 10:16 AM   #1 (permalink)
View BKJDM-MR2's Photo Gallery
USA need help with Air/Fuel Ratio Guage
was up guys i have a question does anyone know how to install an auto meter air/ fuel ratio guage on a 91 MR2 turbo what wires go were?
-thanks
BKJDM-MR2 is offline   Reply With Quote
Old 04-09-2005, 12:23 PM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
http://www.mr2.com/ARTICLE/AutoProAFMonitor.html
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 04-09-2005, 12:26 PM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
red - hot
black - ground
The 3rd wire gets tapped into the BLUE wire on the O2 sensor.
In order to get a solid read on the gauge, it needs to be soldered.
A few things to note:
1. It is normal for the graph to "bounce" at idle and cruise.
That is a correct reading
2. This guage will not tell you ANYTHING about your actual air/fuel ratio at throttle.
If your foot is on the gas, then it should just be showing rich. You need a wideband to read the actual A/F for tuning purposes.
3. This gauge is basically only good knowing if your O2 sensor is working and making sure your ECU is undulating fuel at idle/cruise like it should.
... other than that, it is just a pretty light show.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 04-09-2005, 07:38 PM   #4 (permalink)
thank guys
