Replacing MR2 Timing Belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2005, 11:22 AM   #1 (permalink)
Stock
View whiteblur's Photo Gallery
Hi there, is it hard to replace a MR2's timing belt? How long does it usually take?
whiteblur is offline   Reply With Quote
Old 04-10-2005, 02:49 AM   #2 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
from my experience.... YES (without dropping the engine, and by myself) but it can be done. it took me the better part of a day to do it. it was also my first time to do anything like that to my mr2...so.... but a dealer or repair shop will charge you almost $35,000 (not really, but it's expensive) find the online service manual and have at it.
all you will need is a complete socket set and a phillips screwdriver (I think) start by removing the rear passenger wheel - then remove all engine covers - barely jack up the engine itself just enough to take pressure off of the motor mount - remove the engine braces(pasenger side) and then the motor mount - remove the crankshaft pulley - next use a 10mm socket to remove the No1 and No2 timing belt covers - loosen the idler pulley and tensioner pulley - remove the t-belt and then .. reverse....
ok... it's a little more complex than that but it's a general idea of what needs to be done... .and that's all I could remember doing... it sounds easier than it is... sorry. good luck
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 04-10-2005, 08:09 AM   #3 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
weird, i needed a pulley puller, pry bars, (never needed a phillips other than to remove side access panels), and torque wrenches. other than that i used a bunch of air...
ToyotaTechGeek is offline   Reply With Quote
Old 04-11-2005, 08:18 PM   #4 (permalink)
no more V-6...
I guess I was lucky? I would've loved to use air tools... but, I didn't have any at the time. and ^^ that is what I used the phillips head for as well. just my experience.
back to the 4cyl...
