Using Synchromesh Tranny Fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2005, 07:29 PM   #1 (permalink)
jtl
View jtl's Photo Gallery
I've read here and there about using Synchromesh fluid to quiet down a tranny where the synchromesh's grind a bit. The reading I've done about it seems to say that it is a straight replacement for the stock fluid while some of the posts here are saying they only use 1/3 synchromesh and then 2/3 stock fluid.
Is there any harm in doing a straight replacement or is it better to mix the two. I have a 91 na.
jtl is offline   Reply With Quote
Old 04-10-2005, 08:47 PM   #2 (permalink)
Noob
aosmith's Avatar
View aosmith's Photo Gallery
you could do harm by using an improper mix, it could not stick to gears as well it should cause some parts not to be oiled as well, it also may not provide a proper amount of lubrication
2000 A6 2.8 (the nice car)
chipped (tranny+engine) rear+front strobes, 12" CVR sub
1986 Toyota mr2 (the soon to be race car)
Currently: stripped, engine torn down
aosmith is offline   Reply With Quote
