First Mods? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2005, 12:39 PM   #1 (permalink)
View carrnut21's Photo Gallery
First Mods?
I am new to the MR2, and wondering what would be the first mods to perfrom on a 91 MR2 Turbo, 80K, bone stock. I am more familiar with Hondas and NA cars. I have read that boost controller is a great way to increase power for cheap. Is this true. Any help is great.
Thanks
carrnut21 is offline   Reply With Quote
Old 04-11-2005, 01:22 PM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
First do a tune up. Oil, lube, ignition wires, plugs, distributor rotor, check ignition timing... etc.
Then you could get...
Boost Controller
Boost Gauge
Fuel Cut Defencer (make one, buy a brand name one, plus the hose to your boost pressure sensor.... or PM me... I have a couple laying around)
New exhaust (downpipe also if you have the $)
Read this also... http://mrcontrols.com/primers/power.htm .... it will help you out a lot.
Old 04-11-2005, 03:27 PM   #3 (permalink)
aka "Downforce"
View Strat42586's Photo Gallery
I have a 91 as well. I did exactly what Ish said. But I couldn't afford exhaust, so i just had the catalytic converters knocked out. I like the pull on it, but if you can...get an aftermarket exhaust.
Strat42586 is offline   Reply With Quote
Old 04-11-2005, 10:22 PM   #4 (permalink)
Great, thanks guys!
How much is a boost controller, and how diffucult is the install?
What kind of 1/4 mile times could you run with 220whp?
Old 04-11-2005, 10:45 PM   #5 (permalink)
Piddy's Avatar
Originally Posted by carrnut21
Great, thanks guys!
Boost controller is ~$50 shipped (http://twosrus.com). Take it to the track and tell us about the 1/4 mile time.... it will vary from driver to driver
EDIT: Install should take less than 30 minutes. Getting it to boost what you want it to is the tricky part. Remember... you can't boost over 12psi without an FCD.... 17psi with eliminating fuel cut.... and you REALLY want a boost gauge to go with that controller or you most likely screw your motor up.
