'87 overheating...?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2005, 12:05 AM   #1 (permalink)
booN
View 86AW11's Photo Gallery
looking to buy an 87 but it has overheating probs. the owner believes the water pump is shot. i am wondering if there could be something he hasnt caught, burping, thermo, ??? has anyone had any probs with a water pump that has just quit or clogged lines/radiator? would appreciate it!
86AW11 is offline   Reply With Quote
Old 04-14-2005, 08:10 AM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
i believe that if your pump is shot, it'll make noise...
you could pull the cap and run the car...see if the water moves at all. i would check the coolant and check to make sure that the coolant was bled properly. i would check ignition timing. i would use a Toyota thermostat and coolant (with distilled water). you should probably also use a good coolant flush before making any assumptions about the cooling system.
ToyotaTechGeek is offline   Reply With Quote
Old 04-14-2005, 10:38 PM   #3 (permalink)
Ontario's King of AW11
View yellow86MR2's Photo Gallery
be very carefull and inspect properly for blow head gasket.
Martin
yellow86MR2 is offline   Reply With Quote
Old 04-15-2005, 11:43 PM   #4 (permalink)
Noob
aosmith's Avatar
View aosmith's Photo Gallery
i would expect sound out of the pump...maybe a pinched line somewhere between the radiator and the engine?
2000 A6 2.8 (the nice car)
chipped (tranny+engine) rear+front strobes, 12" CVR sub
1986 Toyota mr2 (the soon to be race car)
Currently: stripped, engine torn down
aosmith is offline   Reply With Quote
Old 04-17-2005, 06:48 AM   #5 (permalink)
i overtake on roundabouts
View feral4.mr2's Photo Gallery
agreed, i would flush the cooling system and install a new thermastat and refill the coolant before jumping to a conclusion.
feral4.mr2 is offline   Reply With Quote
