Need Advice! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2005, 10:49 PM   #1 (permalink)
Noobie With A Dream
View mkIImr2lvr's Photo Gallery
Exclamation Need Advice!
Well, I believe the leaking of the rear main seal on my 91T had become a big enough problem that it needs to be fixed. Does anybody know A) what is involved in doing this and B) Approx. how much it will cost me? If anybody has had to this and would like to give me some help, that would be great! Thanks.
- 2007 Highlander V6 4WD (Wife's DD)
- 1991 Camry DE (My DD)
mkIImr2lvr is offline   Reply With Quote
Old 04-16-2005, 03:44 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998275
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
lets see, rear seal... u must remove left axle, part of suspension linkage, trans, clucth, flywheel, oil pan, then the seal..about 6 to 8 hours labor @$65.00/hr + cost of seal...
The Jedi Speeder at CarDomain
Old 04-16-2005, 03:58 PM   #3 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
rear main seal? basically count on the same cost as a clutch job. i would change the clutch/clutch cover/throw-out bearing while you're in there. perhaps even do the trans axle seals.
ToyotaTechGeek is offline   Reply With Quote
Old 04-16-2005, 04:48 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Hey,ToyotaTechGeek, just curious, but what did you think of my estimate for this work.?
Old 04-16-2005, 05:29 PM   #5 (permalink)
Noobie With A Dream
Thanks guys! I'm gonna have to go get that done here in a couple weeks. I'll let you know what labor is on it. So, if i replace the clutch and such, what would you suggest I replace it with? OEM, or is there something better. Thanks a lot guys!!
Old 04-16-2005, 05:57 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
there's all kinds of clutches out there. if you're stock, an ACT performance clutch would be good. cost less than an OEM from dealer. unless you're going to race at the track, stay away from unsprung or pucked clutches...
Old 04-17-2005, 12:06 AM   #7 (permalink)
MR2BAD-
i dunno, i have never paid for service for any of my vehicles. but it sounds about on-par. i have heard anywhere from 60-85/hour for technician service. ouch! i turn all of my own wrenches.
Old 04-17-2005, 11:42 AM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
ToyotaTechGeek,
I figured u did all your own work. I take it you are a Toyota Tech? I guess someone else probably does the billing..Average tech labor here is $65.00/hour and $85.00/hr for electrical.. anyway, good to have someone with your expertise on the forum...
Old 04-17-2005, 02:14 PM   #9 (permalink)
Noobie With A Dream
Definitely. So, any suggestions on clutch and such...or just go with OEM?
Old 04-17-2005, 08:44 PM   #10 (permalink)
i love my OEM clutch/clutch cover/throw-out bearing. i have an SC, so...
Old 04-17-2005, 10:12 PM   #11 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
the OEM is a good clutch. I have 145k on my abused stock clutch and it's still going strong.although when it comes time for a new one I think I'm gonna get an Unorthodox kevlar clutch and 10 lb flywheel..
Old 04-18-2005, 12:17 AM   #12 (permalink)
Originally Posted by MR2BAD
ToyotaTechGeek,
thanks for your vote of confidence. i'm just an ordinary Toyota lover, though! i've just worked on a bunch of Toyotas over the years! i just try to help if i can!
Old 04-18-2005, 12:18 AM   #13 (permalink)
i've been hearing about Illegal Garage or something like that. Max_Misawa sells them.
Old 04-18-2005, 11:39 AM   #14 (permalink)
Noobie With A Dream
Oops...didn't see that. Alright, well I'll probably go for more of what's cost effective. Thanks a lot guys!
Old 04-18-2005, 11:49 AM   #15 (permalink)
hope any of my ramblings have helped.
