Originally Posted by badazzlegnd
Nato1012 thanks for the tips it already had everything done except those shift cable bearings i am currently doing the t belt and crank seal oil pump oring cam seals and right side rear outer tie rod end. I work at toyota so its not a huge deal for me. The whole reason i have this car is to mod it. Anything else to look out for?
damn if u work for toyota then its in the bag...imnot too sure how much power you want out of this thing but...i would hold off on going with a bigger turbo and use that cash for an LSD. 91's are notorious for kicking out.
As for turbo's im looking into a CT20B..being that it was a stock turbo for later 2's.
im currently on a stock CT26 and it cuts out pretty quick **around 5500 rpm** on its stock form its a decent midrange car. tIm prepping my car for road racing so my mods wont be for huge power..just efficiency and response along with better braking. **Steel Braided Brake Lines** Cross Drilled Rotors, Axxis Creamic Brake Pads, High preformance brake fluid, GM Synchromesh TRanny Fluid..etc etc..damn almost forgot about the tires and weight reduction
