brake light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-23-2005, 06:23 PM   #1 (permalink)
aka "Downforce"
View Strat42586's Photo Gallery
brake light
My e-brake light will come on every once and a while whenever I brake harder than normal. I just flushed the system out about 2k miles ago, and checked to fluid level, and it's good. My brakes are squeaking a little bit, so I know I need to change them. Is that why the light is on?
Strat42586 is offline   Reply With Quote
Old 04-27-2005, 04:33 PM   #2 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
That is most likely the problem. When the pads start to wear really low, more brake fluid must be pushed through the lines in order to close the calipers enough to stop the car. In turn, there is more fluid in the lines, and less fluid in the master cylinder. That's why the brake light goes on for a few seconds on hard braking and why it looks full when you're parked.
I'd definately change the pads. That will most likely solve the problem!
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 04-27-2005, 06:39 PM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
check your brake fluid resoivor in the frunk....low level will cause that dummy light to come on...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 04-30-2005, 06:48 PM   #4 (permalink)
View MitchB's Photo Gallery
Sorry, that's not really true. The pads wear and migrate towards the rotor, using more fluid at the rate of wear, filling the extra space behind the piston.
But, the pads are still the same distance away from the rotor (nearly touching) no matter how much wear there is. So, there's no more fluid used per pedal push. There's just less fluid in the reservoir.
Yes, it's an N/A. It IS a 3.0 liter V6 though. Does that matter?
MitchB is offline   Reply With Quote
