Hand Brake Cable - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2005, 08:44 AM   #1 (permalink)
View thetailwind's Photo Gallery
2nd Generation Hand Brake Cable
My 91 MR2 needs new hand brake cables. im not sure if there are just two cables or if there are multiple ones that lead to the back. Does anyone have a diagram and or part numbers. How much do these cost and where. Ive seen some but im not sure if they are the right ones. If you have the diagram, send it to datailwind@Hotmail.com Thank you
thetailwind is offline   Reply With Quote
Old 04-25-2005, 01:46 PM   #2 (permalink)
View Walka's Photo Gallery
looks like this is for the MK1..
http://www.padandwheels.com/mr2/park...kingbrake.html
not to long a list to how to do it...seems pretty easy
with mine there is the exhaust and heat shield in the way..but that shouldnt be a problem for you cause its MR
the cables freezing up seems to be something common
Walka is offline   Reply With Quote
Old 04-30-2005, 07:06 PM   #3 (permalink)
View MitchB's Photo Gallery
Two cables, about $40 each from discounting dealers. By all means, replace both of them. You have to have the car on jack stands so you can remove the undercovers from the brake lever back. It's easy, but a little time consuming, from an hour to two hours, depending on how fast you work.
Yes, it's an N/A. It IS a 3.0 liter V6 though. Does that matter?
MitchB is offline   Reply With Quote
