Engine swap information - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2005, 12:12 AM   #1 (permalink)
View mrboogie33's Photo Gallery
USA Engine swap information
Hello chat Im purchasing a 93 MR2 nonturbo. I wanted to know how hard is it to swap a turbo engine into the car? Is it really worth it or should I just turbocharge the nonturbo engine?
mrboogie33 is offline   Reply With Quote
Old 04-26-2005, 01:19 AM   #2 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
The swap is relitivly easy... just make sure you have a complete clip. If you don't have complete clip or a half cut.... you will be hunting for parts and get all confused. It would be cheaper to just start with a turbocharged car first though.
Old 04-27-2005, 09:11 AM   #3 (permalink)
Yeah I would like to get one with the turborcharger already but I cant find one + Im only paying 1800 for this one.
Old 04-27-2005, 01:54 PM   #4 (permalink)
View Mike@Fidanza's Photo Gallery
FYI: DROP THE MOTOR FROM THE BOTTOM! I had the worse time trying to do it from the top...
Mike@Fidanza is offline   Reply With Quote
Old 04-27-2005, 01:58 PM   #5 (permalink)
Will I be able to do the swap myself? That is the big question. I also would like to use the AEM stand alone computer for the setup but Im not sure if it would work with the JDM engine.
Old 04-27-2005, 02:02 PM   #6 (permalink)
It'll work with the JDM motor, but I'd be more concerned about doing the swap and getting that to run good before doing any engine management.
Depends on how mechanically inclined you are as far as the swap is concerned!
I did my swap on my own but needed some help getting the motor positioned w/ the mounts.
Old 05-02-2005, 11:48 AM   #7 (permalink)
Okay cool, I also wanted to know will most of the aftermarket parts that are made for the US turbo engine work with the japanese version. A lot of people tell me it wouldn't. I also wanted to get the motor rebuilt. Im planning on making between 400-500 hp. Does anyone know where I can get the main bearings and other internals for that engine from? Any website suggestions. I know www.raceng.com has some.
Old 05-05-2005, 11:56 AM   #8 (permalink)
View drew6650's Photo Gallery
If someone was to only get the engine, ecu, how hard would the swap be? Do the trannys bolt up the same? Engine mounts line up? Anyone have any knowledge 1st hand? Thanks!
drew6650 is offline   Reply With Quote
Old 05-05-2005, 04:10 PM   #9 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
motor mounts will match... i think the trans will too, but id check with others just in case. youll need turbo axles also... it is MUCH better/easier to buy a clip. just ask anyone here.
Function over form.
Drifting Dane is offline   Reply With Quote
Old 05-05-2005, 07:15 PM   #10 (permalink)
Thanks for the response!!! Is there anyone in particular I need to ask? I have a friend of the family who can import this engine and ecu, but said nothing of the clip. I have so many questions and would greatly appreciate speaking to someone who has bone this!
Old 05-05-2005, 09:45 PM   #11 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
I bought most of my parts from www.importperformanceparst.net Instead of searching for individual parts... they sell complete kits... pistons\rods\bearings\gaskets... they have a lot of stuff for 3sgte's and 5sfe's also.
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 05-06-2005, 02:10 AM   #12 (permalink)
Piddy's Avatar
Get a full clip or a half cut.... you will thank us all later. If you don't.... you can expect to go on a long tedious part hunt. You CAN... but wouldn't want to use your NA tranny. It won't hold the turbo engines power for very long.
