Synchro Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2005, 01:28 PM   #1 (permalink)
Mechanical Marvel
BigXRobot's Avatar
View BigXRobot's Photo Gallery
Synchro Question
Hello All
I'm new around here, and in all fairness I technically shouldn't be posting on this forum yet. I don't currently own an MR2, however I may be purchasing a '92 turbo later tonight. I've been told that the only mechanical problem with the car is that the 1-2 and 2-3 gear synchros are just starting to go bad. I was just wondering how long the synchros usually last in these cars and how expensive it is to fix them. I've owned a couple of Supras in the past so i'm familiar with Toyotas. I'm also pretty hands on guy so i guess that i'll need to know whether this will be a DIY job or not as well. Thanks.
BigXRobot is offline   Reply With Quote
Old 04-28-2005, 11:03 AM   #2 (permalink)
View sdubk's Photo Gallery
Only way to know for sure is test drive. I have a 91 that had notchy shifts, but new shifter bushings and gear oil change fixed it for the most part, and did so inexpensively. If the price is right, you could source a 93+ tranny with dual synchros, which are much better than the 91 single synchros.
sdubk is offline   Reply With Quote
Old 04-28-2005, 05:51 PM   #3 (permalink)
Noob
aosmith's Avatar
View aosmith's Photo Gallery
its not so much that the part is expensive...its a b!tch to replace...you should feel notchy shifts as described above
2000 A6 2.8 (the nice car)
chipped (tranny+engine) rear+front strobes, 12" CVR sub
1986 Toyota mr2 (the soon to be race car)
Currently: stripped, engine torn down
aosmith is offline   Reply With Quote
Old 04-30-2005, 06:40 PM   #4 (permalink)
View MitchB's Photo Gallery
Synchromesh. Do a search on here and on MR2OC and you will find your answer.
Simply put, go to Autozone and buy four quarts of Pennzoil Synchromesh. Drain your tranny and refill with the Synchromesh. You will be amazed, but it will likely take a hundred miles ore more.
Yes, it's an N/A. It IS a 3.0 liter V6 though. Does that matter?
MitchB is offline   Reply With Quote
