alright, I noticed when I hit the brakes, or use a turn signal... the voltage drops instantly, but the is immediately back to normal.... it makes my headlights dim ( kinda like I'm flashing my brights ) I just noticed this after I installed a new amp and sub.... everything is properly installed, wired correctly.... could there be a bad ground somewhere causing this? I replaced my terminals before the install, hooked everything back up and it all seemed to work fine. but this evening I notice the voltage jumping because I had my headlights on..... any ideas...? I'll probobly just go back over everything I've changed since I noticed the problem... I hate electrical problems
