Mr2 Overboosting problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2005, 01:23 PM   #1 (permalink)
View closmr2's Photo Gallery
2nd Generation Mr2 Overboosting problem
Hey Toyota Nation first time posting on here. I had a question about my 92 mr2 turbo, it seems that when ever i get on the gas my boost goes up to about 14lbs than it cuts off i know that the cut of is the fuel cut defenser but i was wondering what can be causing my car to overboost everytime i step on it . My car only has an intake and dual greddy exhaust no engine mods or boost controler. Thanks for ur help Toyota Nation
Clos
closmr2 is offline   Reply With Quote
Old 05-03-2005, 01:27 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
sounds like your wastegate may be stuck or actuator is failing...
The Jedi Speeder at CarDomain
Old 05-03-2005, 02:13 PM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Any improvement in the OEM exhaust will be enough for you to hit fuel cut.
Fule cut only comes at 12 psi, not 14.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 05-03-2005, 02:15 PM   #4 (permalink)
Rockin the STi
View onehotcamry's Photo Gallery
mods usually bump ur boost up a little
edit* saw that the doc posted already :p
04 WRB STi - Stg. 2
93 White Mr2T - 263 rwhp @ 10psi
95 Black Mr2T - TKO exhaust
04 Suzuki GSX-R600
onehotcamry is offline   Reply With Quote
Old 05-03-2005, 03:40 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
is your fuel cut disabled? are u sure you're hitting 14psi? what kind of boost gauge are u using?
Old 05-03-2005, 09:36 PM   #6 (permalink)
View manny0ne's Photo Gallery
wow, i was actually gonna post the same exact thing. I have a '91 turbo and i have my fuel cut disabled. I'm actually hitting 15 psi, though. -=/ I bought the car with intake and turbo XS BOV. Sure doesn't pull like 15 psi ;( Any ideas?
- Oh, i'm using an Autometer mechanical boost gauge.
manny0ne is offline   Reply With Quote
Old 05-04-2005, 12:40 AM   #7 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
switch back to stock bypass valve? they perform better than your aftermarket bov.
Function over form.
Drifting Dane is offline   Reply With Quote
Old 05-04-2005, 08:24 AM   #8 (permalink)
yeah i'll have to try that, too ;( i raced my best friend in his 2.. it sucked real bad ;(
Old 05-04-2005, 11:26 PM   #9 (permalink)
Thanks i'll have the wastegate checked out and the actuator. I'm using an autometer gauge thats hooked up straight to the boost line on turbo and not the boost sensor.
