Actuator problems? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2005, 08:21 AM   #1 (permalink)
View ricerx614's Photo Gallery
Actuator problems?
car boosts to no end. i have a MBC set to the lowest setting. cant move tha actuator arm at all, no wiggle, nothing.
can the actuator be replaced? how do i test to see if its bad?
searched the faq, didnt find anything.
i have a few extra actuators off of some vw turbos, do you think i can swap them out?
the vw arms are a bit shorter but i got some JB weld.
can you move the actuator by hand?
ricerx614 is offline   Reply With Quote
Old 05-09-2005, 11:26 AM   #2 (permalink)
View OEMonkey's Photo Gallery
http://www.mr2-tech.com/bgb/mechanic...ger_system.htm
make sure your mbc is routed correctly. make sure to check the vac hoses. if the tvsv is not used, make sure the ends are capped and plugged.
OEMonkey is offline   Reply With Quote
Old 05-09-2005, 09:38 PM   #3 (permalink)
nice!
we took the intake pipes off, used the vice grips and gave it a good shove, and head it snap back into place, hooked everything up and it worked. well sorta
