surging idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2005, 12:35 AM   #1 (permalink)
82toyo's Avatar
View 82toyo's Photo Gallery
Gen1 surging idle
I have a 1989 n/a and when it is cold the idle will surge up and down and after the car warms up it will stop surging and idle fine. Wondering if anyone else has had this problem or have an idea of what it might be. I have bled the coolant several times as someone told me that might be it but never changed the idle. Thanks for any help.
82toyo is offline   Reply With Quote
Old 05-12-2005, 08:38 AM   #2 (permalink)
View gkcopperdrag's Photo Gallery
Had this problem with my ford probe. Its called "Hunting" from what I was told. Never hurt the engine or anything.
~GK
92 Toyota Celica GT
91 MR2 N/A
gkcopperdrag is offline   Reply With Quote
Old 05-12-2005, 02:26 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
most cars have an "idle up" valve that keeps RPMs up till it's warmed up. RPM's should lower to normal after the engine has warmed up.
The Jedi Speeder at CarDomain
Old 05-12-2005, 05:01 PM   #4 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
Yea, my '91 turbo does it all the time. Whenever I start it in the morning, it revs to like 2k, and slowly comes down, as it warms up.
My '97 RAV4 will actually bounce around for a while. It goes from 1k to 2k, down to 1.5k, back up to 2k, then finally settles at about 950 RPMs.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 05-12-2005, 10:12 PM   #5 (permalink)
johnr's Avatar
View johnr's Photo Gallery
Check and adjust your speed control sensor, it should be located on your throttle body. Here check this out http://www.mr2-tech.com/bgb/mechanic..._system/16.htm I had the same problem. Fixed.
johnr is offline   Reply With Quote
Old 05-13-2005, 05:32 AM   #6 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
The MKI MR2s have a tendecny to "hunt" at idle when the cooling system has air in it.
I suspect if you properly bleed your coolant system you will get rid of the hunting idle.
At the least, I would top the system off.
Good luck.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 05-13-2005, 06:23 AM   #7 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
i can't agree that it 'won't hurt anything'. fix that thing!
ToyotaTechGeek is offline   Reply With Quote
