just got my sw20. had a ? is 1st gear suppose to boost? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-20-2005, 01:58 AM   #1 (permalink)
View aspr81's Photo Gallery
when i drive and i'm in 1st gear there is no boost. but in other gears i have boost is that normal? and if not what can i do to fix it or if its normal what can i do to make it boost in 1st gear. thanks
aspr81 is offline   Reply With Quote
Old 05-20-2005, 05:58 AM   #2 (permalink)
View vtsuckah's Photo Gallery
what rpm are you shifting at to go to 2nd gear?
vtsuckah is offline   Reply With Quote
Old 05-20-2005, 12:29 PM   #3 (permalink)
View gkcopperdrag's Photo Gallery
What you're probably experiencing is "turbo lag". Busy at work if anyone else could explain it.
~GK
92 Toyota Celica GT
91 MR2 N/A
gkcopperdrag is offline   Reply With Quote
Old 05-20-2005, 12:39 PM   #4 (permalink)
View djwolford's Photo Gallery
If I had to guess it's just turbo lag, it takes a few seconds for your turbo to spool, so most of the time I'm guessing that it doesnt spool up before you get to 2nd.
Smaller turbo? other than that you'll just have to live with it I guess.
05 Corolla Xrs-Super white, 6-spd.
Injen Cold Air Intake, Sun hyper voltage/hyper ground systems, Hotchkis Front/Rear sway bars, and a few random trd goodies.
www.djwolford.com
djwolford is offline   Reply With Quote
Old 05-20-2005, 12:56 PM   #5 (permalink)
N/A bites
Tercel GTS's Avatar
You might pull the intake off the compressor side, reach in and see if the shaft has play. Mine was actually dragging, therefore creating extra lag. All it takes is a little play, turbos are pretty close tolerance.
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
Old 05-20-2005, 01:40 PM   #6 (permalink)
thanks guys for all the help. i'll check the intake to see ifs its dragging. and i shift at high rpms in 1st. in 2nd the turbo starts kicking in at 2800rpm. do all u guys experience this in 1st gear? is there anyting i can do to decrease to turbo lag?
