Oil in upper intercooler pipe/throttle body inlet - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2005, 03:59 PM   #1 (permalink)
aka "Downforce"
View Strat42586's Photo Gallery
Replaced spark plugs and wires. Plugs had a lot of black residue around the threads and gaskets and the area between the electrodes and threads, but the electrodes themselves looked normal. I pulled off the upper intercooler pipe to make it easier to get to plug numbers 1 and 2, and I looked inside of the pipe, and inside of the throttle body inlet, and there was a thin, transparent layer of oil that coated much of the interior. It wasn't a large amount by any means, but I was wondering if this is normal or not.
Strat42586 is offline   Reply With Quote
Old 05-26-2005, 04:57 PM   #2 (permalink)
DerekDorifto's Avatar
View DerekDorifto's Photo Gallery
That's normal, it's oily vapour buildup. Remove the IC and you can clean it out by swishing degreaser or some gasoline inside to flush it out.
AW11 / AE86 / AE100
DerekDorifto is offline   Reply With Quote
Old 05-26-2005, 05:48 PM   #3 (permalink)
aka "Downforce"
Awesome, thank you!
Old 05-26-2005, 07:12 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
i agree..seems to be normal. I have the same, not much but everything seems hunky dory ...i guess as long as the plugs are wet with oil..
The Jedi Speeder at CarDomain
Old 05-26-2005, 07:26 PM   #5 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
It's because of the pcv valve. If you don't want the blow-by oil recirculated through your intake, turbo, and intercooler, you can remove it from your intake pipe and put a filter on it.
But yes, it's normal.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
