need help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-27-2005, 09:20 PM   #1 (permalink)
View mr3sgte's Photo Gallery
Question need help
hey guys i need your help...i just swapped a jdm 2nd gen 3sgte on my two and im having some white smoke coming out of my exhaust...well the white smoke comes out when ever the car is in idle...but when i drive the car, the smoke seems to go away or disappear and goes back again when it's in idle...what dya guys think is the problem?...any suggestions would be helpful.
mr3sgte is offline   Reply With Quote
Old 05-27-2005, 10:54 PM   #2 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Could be your head gasket
Check coolant for oil and bubbles, check oil for coolant. Check spark plugs.
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 05-27-2005, 10:55 PM   #3 (permalink)
View mr.ikon's Photo Gallery
you might have a blown head gasket, had the same problem so im rebuilding the engine cause i just got my car.
mr.ikon is offline   Reply With Quote
Old 05-27-2005, 11:27 PM   #4 (permalink)
thanks guys...i was thinking it's is the head gasket also but im a noob so i wanna make sure if it is the head gasket...ohhh yeah since i'll be changing the head gasket...is there any more tune up i have to get done since im not really sure if how much mileage i have with my engine...but if you look at the engine visually the engine seems it hasn't been used that much...i say this because i didn't see any oil leak ever since i bought the engine, and the sealants seems like it's brand new and i don't see much corrosion...
Old 05-28-2005, 12:26 AM   #5 (permalink)
if youre gonna go through with all that stuff, you might as well change the timing belt and water pump.
Old 05-28-2005, 07:11 PM   #6 (permalink)
View *01 TRD Camry*'s Photo Gallery
u said white smoke it could b the valve seals. So u are better off rebuilding the whole engine while u at it.
*01 TRD Camry* is offline   Reply With Quote
