well, if you can find the Blitz, then it'll probably be used. the others seem to be kind of non-existant for some reason. anyway, i'm happily using an HKS until i re-build/rebalance my rotating assembley...i'm a stickler for NOT throwing the balance of the rotating assembly off by adding a larger pulley. if you're wondering why you would use a larger pulley rather than smaller, it's because you need to look at things from the standpoint that the crank pulley will adversely affect the aspect ratio of all of the other pulleys when made larger.
BTW: unless you are going to use some sort of piggyback or full EMS, or even Grunt box, you may/will be introducing some potentially damaging engine conditions that will be un-favorable.
