Got cams? Got brakes? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2005, 11:50 AM   #1 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
If you have installed longer duration or high lift (or both) cams, you may have noticed your brakes are not as wonderful as they used to be. Since our brakes are assisted by the intake manifold vac, pulling less vac at idle with big cams can make this interesting in a bad (read dangerous) way.
I know my brakes were out right scary until NoShoes tuned my car. They are "good" now, but occasionally they still suck. Enough that it would cause me great concern while hill climbing the car.
Thanks to Jim (aka redblues), I found out about this nice little part:
Did you install a large cam and gain problems with your power brakes?
These kits allow you to store the vacuum you need to use your vacuum-assisted power brakes. These systems use a one-way check valve that will store the vacuum until you need it. The kits can be installed in tight areas, and come complete with all necessary hardware, except for the power brake hose.
http://store.summitracing.com/partde...=KeywordSearch
I just ordered mine.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 05-31-2005, 12:04 PM   #2 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
Wow, good to know!
ratko.org
Ratko is offline   Reply With Quote
Old 05-31-2005, 08:54 PM   #3 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
that never even crossed my mind! glad someone out there is constantly thinking.
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 05-31-2005, 09:23 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
good post Doc.. I have my HKS 264 cams to install sometime in the very near future... I will have to address this issue too...
The Jedi Speeder at CarDomain
Old 06-01-2005, 05:31 AM   #5 (permalink)
Fist of the North Star
View Komodo's Photo Gallery
I will be needing one of those in the near future.
Komodo is offline   Reply With Quote
Old 07-12-2005, 10:47 PM   #6 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
hey Jeff, just checking in to see if this project had been completed yet or not... any pics of mounting location? Also, where did you get the "power brake hose" that is needed for the install? is it easy to do?
Function over form.
Drifting Dane is offline   Reply With Quote
Old 07-13-2005, 05:26 AM   #7 (permalink)
I love Cin
Yes it is installed and I have been using it with no problems.
We actually did not get anyhose yet ... we sort of rigged the OEM hoses to work.
It's safe, just not very pretty. I'll see what I can do about getting a photo for you.
