tire width?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-31-2005, 10:59 PM   #1 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
tire width??
does anyone have an idea of the widest tire I could run on a 7"wide wheel? I currently am using 205mm... could I go as far as 225's??
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 05-31-2005, 11:14 PM   #2 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
You can easily go 225 on a 7" rim. You can go wider than that. The stock 15's are 15x7 rear and have a 225 on them.
I'm pretty sure Jeff Fazio (Hyde) had 255's on a 7.5" rim (I think) at one point.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 05-31-2005, 11:14 PM   #3 (permalink)
4DMR2t's Avatar
And somehow, I double posted! Disregard this please!
Old 06-01-2005, 05:06 AM   #4 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
The widest street tire you can get on there with very little issues is a 235.
That is what I run on the back of both of Jekyl and Hyde on the street.
A 17X7 with a 235.
NoShoes Moore actually squeezed a 245 onto the same rim, but I do not recommend that.
I have run a 255 drag radial on a 16X7, but DRs are designed entirely different.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 06-02-2005, 11:44 PM   #5 (permalink)
no more V-6...
thanks guys
back to the 4cyl...
Old 06-12-2005, 01:13 AM   #6 (permalink)
no more V-6...
J&H.... you said with "very little issues".... please explain. I just don't want to hit a bump and pop the seal around the wheel! I think I'm gonna go with the 235\50\17 brigdestone potenza's.. for the rear of course. and stick with my 205's up front.
back to the 4cyl...
Old 06-12-2005, 05:31 PM   #7 (permalink)
I love Cin
As indicated in my post, you will have very little issue .. if you went bigger, I would be more concerned. As for the seal popping, I set the Weatherly Hill Climb record last year on a 235 Falcon street tire. I wouldn't expect you to ever put a tire under that kind of pressure ... and if you a hit bump bad enough, it's not going to matter wwhat size tire is on there.
Old 06-12-2005, 06:29 PM   #8 (permalink)
no more V-6...
that's good to know.. I don't think my mr-2 will be making any hill climbs in the near future! thanks again for the input.
back to the 4cyl...
Old 06-13-2005, 12:35 PM   #9 (permalink)
View gkcopperdrag's Photo Gallery
Hyde,
I'm getting new tires soon ( bought the car with 17x7 front and back ), 215's all four atm. They rub up front and wanted to know what tire size you'd recommend for the front to eliminate ( or reduce ) that problem.
~Thanks
~GK
92 Toyota Celica GT
91 MR2 N/A
gkcopperdrag is offline   Reply With Quote
Old 06-13-2005, 01:48 PM   #10 (permalink)
no more V-6...
a friend of mine had the same problem... with the same tire size... so he has put a 205 up front.. hasn't rubbed yet
back to the 4cyl...
Old 06-13-2005, 01:49 PM   #11 (permalink)
I love Cin
oh, MR-355-5sfTe, I would recommend a 215 up front!
gkcopperdrag, you should not have the same size tire all the way around on a MKII MR2.
Where are they rubbing? Are the rubbing the strut or the fender? There is no way a properly sized 215 should be rubbing up front.
If it is hitting the strut, it sounds like you have the wrong off set on the rim. You may have to go to a spacer or a different wheel.
If it is hitting the fender it sounds like the tire is way too tall.
Old 06-13-2005, 02:13 PM   #12 (permalink)
fender, will grab the exact size when I leave work~
~GK
92 Toyota Celica GT
91 MR2 N/A
Old 06-14-2005, 08:00 AM   #13 (permalink)
215/45/R17
The top of the tire on the inside 2" is worn down significantly more than the rest of the tire.
Thanks for any feedback~
~GK
92 Toyota Celica GT
91 MR2 N/A
Old 06-14-2005, 08:38 AM   #14 (permalink)
I love Cin
That's your problem! ... your tire is way too tall.
A typical 16" for a MKII up front is: 215/45/16.
A 215/45/16 = 599.9 tall.
Let's talk 17s. If you have a taller rim, you need a SMALLER sidewall.
If you run a 215/40/17 = 603.8 tall (it is a little taller than stock)
If you run a 215/35/17 = 582.3 tall (it is a little shorter than stock)
You 215/45/17s = 625.3 tall! No wonder they are rubbing!
Old 06-14-2005, 08:38 AM   #15 (permalink)
I love Cin
You should do a lot of reading here:
http://www.mr2.com/Tires.html
