If you have a 5SFE then you can get away without removing the throttle body. If it is the oil seal that is on the camshaft end on the timing cover side, then you just need to remove the plug wires, nuts/wahers on the spark plug tubes, and the valve cover. It will be the intake camshaft but you will need to remove the exhaust camshaft first since it has two gears that are spring loaded. You need to insert a bolt in the serice hole of the exhaust camshaft gears to hold them in place so they don't move. After all the bearing caps are removed (and remember they are numbered to go back in the same spot), then you can remove the intake camshaft bearing caps, etc. The seal should just come off.
The manual says to tap the seal in after you re-insert the camshaft but there really is no room to do it so install it on the bearing surface before putting the camshaft back in. reverse the process to put it back together.
I had to do this a few times and after the third time it took me probably about 1 hour or so to do it. A shop may tear down more than that to get at things. Just wanted to give you an idea of what's involved in case you want to try or so you can talk to the dealer and he won't be able to give you alot of garbage. Good luck.
