removed EGR - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-07-2005, 06:01 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
removed EGR
OK, I removed my EGR and blocked off with plates. but there are 2 vacuum lines left open.. should I cap them?leave them open? what about the little valve thingy? can I just take it off? My idle seems to fluctuate just alittle bit. very steady and rythmic between 750 and 1000 rpm.. is that normal?
The Jedi Speeder at CarDomain
Old 06-07-2005, 07:19 PM   #2 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
so you finally went through with it!! congrads. as for the vacume lines.. try capping them and then checking the idle... just a suggestion? now when you removed the egr.. did you remove the charcoal canister as well?? <--- not sure if you'd need to or even want to...
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 06-07-2005, 07:30 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I put my fingers over the hose ends and watched the tach-no difference. it's not that noticeable. just annoys me to see the tach do that. I didn't remove the charcoal canister. i heard it gets smelly when you do.. but should I?
Old 06-07-2005, 07:47 PM   #4 (permalink)
no more V-6...
wish I could tell you... but I have not yet dove into that part of the car... I generally tend to wait until something breaks.... I just can't find the time to mod lately... I just assumed that the egr and charcoal canister would be in the same system.. and since you removed the egr valve... I thought you might have removed everything associated with it.
back to the 4cyl...
Old 06-07-2005, 07:57 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I don't see any lines/hoses go to/from EGR to the canister..there is a electrical connector and 2 other valve looking type things attached to vacuum hoses coming off the throttle body that have me concerned. car is running well though. I drove it a bunch after I took off the EGR yesterday....
Old 06-08-2005, 03:01 AM   #6 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Is there any difference??? Just curious. I have no EGR myself... but mine came that way.
Old 06-08-2005, 09:22 AM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
nothing noticeable, but I'm going to be installing this intake manifold and it doesn't accept the EGR... so i thought i would take it off first to see what the effect or problems might be
Old 06-08-2005, 09:26 AM   #8 (permalink)
Gameroom cash: $147537
EGR is for lower chamber temp and better gas mileage. Don't remove the charcoal, its to recover fuel fume and burn them again. Cap all the vaccum lines.
Old 06-08-2005, 09:30 AM   #9 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Thanks Pineapple...and BTW..Pineapple???
Old 06-08-2005, 12:20 PM   #10 (permalink)
no more V-6...
nice manifold btw.
back to the 4cyl...
