problems with my 91 non turbo mr2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2005, 08:37 AM   #1 (permalink)
View mr2trbo93's Photo Gallery
i have a 1991 mr2 non turbo...can any 1 tell me what engine thaqt is?it is not starting and when it does i give it quick throttle and all it does is bogg or wants to stall but when i give throttle slowly its fine does ne 1 know what the problem could be??does anybody have a 3sgte head for sale anda price?>?
mr2trbo93 is offline   Reply With Quote
Old 06-08-2005, 08:39 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Your engine is the 5SFE.
A 3GTE head is not going to resolve your issue.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 06-08-2005, 12:13 PM   #3 (permalink)
3sgte
the 3sgte head will give you more power??correct me if im rong but the 3sgte head will bolt right up to the 5sfe block and i will be able to hold up a stock 7 lbs.. turbo
Old 06-08-2005, 12:42 PM   #4 (permalink)
I love Cin
Well first of all, if you are coming engines like that there is no "stock 7 lbs."
Secondly, strapping a turbo head onto the 5SFE does not suddenly make it a great engine to turbocharge. The 5SFE is not a great starting place for boosted power.
Can it be done? Yes. Is it a great idea or the best place to start? No way.
Lastly, if you are having problems with your current set up, I would not suggest using that as a platform to experiment from.
Just my 2 psi.
Old 06-08-2005, 02:02 PM   #5 (permalink)
Gameroom cash: $147537
Check ground wires and ignition. Try another ignition coil. Check fuel filter, fuel pump, ignition timing, spark plug, cylinder compression etc.
Old 06-08-2005, 06:28 PM   #6 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
water in your intake (not sure what kind you have) will do what you are describing, did you wash it recently with anything that could have gotten water up in your intake tubing? (like a pressure washer)
When i knew nothing about my car, i would wash it almost every day with a pressure washer and wonder why it ran like shit for a day after i had washed it.
If not, it will probably need new ignition components as pineapple pointed out.
Function over form.
Drifting Dane is offline   Reply With Quote
Old 06-08-2005, 09:31 PM   #7 (permalink)
power wash
my bro power washed it but the problem happened a week later
Old 06-10-2005, 10:54 PM   #8 (permalink)
jtl
View jtl's Photo Gallery
Correct me if i'm wrong but how can you bolt a 3GTE head to a 5SFE since the 5sfe has a slaved exhaust camshaft while the 3gte has independent camshaft gearing (in other words, the 3gte has two timing pulleys versus one for the 5sfe).
jtl is offline   Reply With Quote
Old 06-10-2005, 11:17 PM   #9 (permalink)
Boosting 15 psi :)
the 3s has two cam gears, but not two timing belts... one belt runs both of them, just get a timing belt for the 3s and put it on when you swap heads.
Function over form.
Old 06-11-2005, 10:09 AM   #10 (permalink)
jtl
OK Drifting Dane. That make's sense. Thanks.
