Coolant Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-08-2005, 11:19 AM   #1 (permalink)
View skybandit's Photo Gallery
Unhappy Coolant Leak
The day after my 91 N/A overheated I filled the coolant and radiator fluids up and started the car to check for leaks.Low and behold I found coolant leaking from underneath the car about right smack at the middle of the car.Any ideas of the source of the leak,which hose,etc...?Thanks for any input.
skybandit is offline   Reply With Quote
Old 06-08-2005, 11:29 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
In the middle of the car are 2 lines that run back-n-forth from the radiator the engine.
However, it is possible that the leak is somewhere else entirely and is just running down the under trays to the lowest point and dripping there.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 06-08-2005, 09:20 PM   #3 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
aren't those "hard lines" that run under the car? I would guess the same as J&H.. check the rubber hoses where they connect to the hardlines.
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 06-08-2005, 09:53 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I had a similar problem a couple of weeks ago and it was one of those clamps you just "pinch open" on the upper hard pipe running to the radiator.the coolant ran down towards the center like Doc J indicated...look like it was coming out of the middle of the car.. put a new clamp(screw type) and it was fixed
The Jedi Speeder at CarDomain
