what about your ignitor coil? since you have a '93 model (same as mine) the coil is inside the distributor... if you swap the wires and that doesn't help, try testing the coil. mine just went out one day right after I left the driveway... I was stranded 300 yards from the house! I pushed the car back (uphill) and tore it apart... changed wires, plugs,distr. cap, rotor.... didn't help a bit. so I thought I'd just buy a new distributor (last possible thing right?)... I get it home and pull out the new coil...swap it into my old distr... and bam! fired right up. -- keep in mind the parts stores will not accept a "tampered with" distributor...so be careful. I then put the coil back into the new distributor... and returned it. then I simply bought a coil..... I guess I could've said that in fewer words, but what the hell.
back to the 4cyl...
