Head Gasket question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-11-2005, 05:44 PM   #1 (permalink)
View skybandit's Photo Gallery
Question Head Gasket question
About how much can one expect to pay to have the head gasket replaced on a 91 N/A? Does anyone know any good shops to take it to get replaced in the Pittsburgh,Pa area??Thanks.
skybandit is offline   Reply With Quote
Old 06-11-2005, 07:49 PM   #2 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
about a grand <--- rough estimate. labor prices are about $70 per hour....
the gasket itself inst expensive, if you are mechnically inclined (or have friends who are), i would change it myself.
if you do change it yourself, make sure your head/block arent warped. Its a full day project, may be shorter/longer depending on your experience with automobiles.
Function over form.
Drifting Dane is offline   Reply With Quote
Old 06-12-2005, 12:43 AM   #3 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
I just wish we didn't have to pull the cams to remove the head... that's the tedious part for me.
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 06-12-2005, 04:43 AM   #4 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
I think a grand is a little steep. I got my friend an estimate on changing the head gasket for his SR20DET from the shop I go to and they only wanted $300.
Old 06-12-2005, 12:34 PM   #5 (permalink)
View rony's Photo Gallery
So what is needed to do a hg? Valve cover gasket, new headbolts, HG, what else?
rony is offline   Reply With Quote
Old 07-01-2005, 09:52 PM   #6 (permalink)
View spiderx's Photo Gallery
I just got a head gasket kit from toyota. It comes with all the gaskets
starin at the world thru my rearview
spiderx is offline   Reply With Quote
Old 07-14-2005, 12:07 AM   #7 (permalink)
All Function
View anarkia1ces's Photo Gallery
Are you sure it is the headgasket? Have you done a compression/leakdown test? What are the car's symptoms? Expect to pay around 1G. The Gasket Kit (Engine rebuild Gasket Kit) from Toyota has all of the neccesary parts for the job. If the car overheated, I would also change the thermostat and gasket, Cap and oil filter. Right after the headasket change, change the oil as well as it may contain some coolant that entered the crank case through the broken HG.
anarkia1ces is offline   Reply With Quote
Old 07-14-2005, 12:24 PM   #8 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
did u fall down and hit your head on something....forgetting how hard and back breaking it is to work on a mid engined car like ours.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 07-14-2005, 12:52 PM   #9 (permalink)
All Function
I have to agree. No sober mechanic will ever, EVER do this job for $300, unless he is trying to date your sister or something.
