got a quick BORE question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-13-2005, 04:37 AM   #1 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
Question got a quick BORE question
ok.. the stock bore on a 5sfe is 87mm.... I've located a basically "new" block for a build. it's been bored over .040 , honed, planed, hot-tanked, and new freeze plugs installed...
my question is: it's been bored .040 .... what size piston should I go with? would the stock 87mm cover the gap? or should I get something like an 87.5 or larger? I need some expetise... and some learnin'
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 06-13-2005, 09:56 PM   #2 (permalink)
no more V-6...
ok.. so I should just measure the block once I recieve it? then have special pistons made to fit? any help.
back to the 4cyl...
Old 06-13-2005, 10:58 PM   #3 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
well..... .04 inches (i beleive this is the standard overbore unit of measure) is equal to 1.016 mm
so its damn close to 1mm... but, im not sure if when boring out the amount of overbore if it is measured with respect to the radius or diamiter. I have no experience with bored engines, so anyone who has, please let us know shich case it is.
Function over form.
Drifting Dane is offline   Reply With Quote
Old 06-14-2005, 12:12 AM   #4 (permalink)
no more V-6...
dane.. thanks to your info, I know more than I did before I posted.
back to the 4cyl...
Old 06-15-2005, 12:57 AM   #5 (permalink)
View 91RED3S's Photo Gallery
88mm
complete JDM Gen 2 engine, Tubular stainless manifold and 3" downpipe, Turbo XS Type H RFL blow-off-valve, Konig Holes 17" rims, Faze Boost Gauge, soon: HKS Vein Pressure Converter & Fuel Cut Defender, KYB AGX Struts, RS*R RACE Springs
91RED3S is offline   Reply With Quote
Old 06-15-2005, 02:00 AM   #6 (permalink)
no more V-6...
great.. so an 88mm piston will fit almost perfectly.
thanks 91red
back to the 4cyl...
