Speedo question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-17-2005, 07:00 PM   #1 (permalink)
View blur2000celica's Photo Gallery
Speedo question
I have a 93 n/a with a 91 usdm turbo swap, and my question is how can I get the speedometer to work? I know I could use the mechanical cable to a certain point, but what happens after that? Or would it be easier to find a 91 cluster and go that route? any help is appreciated
blur2000celica is offline   Reply With Quote
Old 06-17-2005, 08:51 PM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
The 93s have a sensor that sends a signal to the dash.
There is NO mechanical cable.
The 91s have a mechanical cable that goes all the way up to the dash.
You can't mix-n-match. Either you get a 91 cluster or you get the sensor installed into your tranny. I suspect a cluster is going to be much cheaper.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 06-17-2005, 09:40 PM   #3 (permalink)
thanks for the input
Old 06-19-2005, 12:52 AM   #4 (permalink)
how easy would it be to install 91 cluster into the 93? would it be a basic plug in except for the speedo cable which ill need to get
Old 06-25-2005, 07:16 PM   #5 (permalink)
View MitchB's Photo Gallery
Do it right and go buy the speed sensor you need. There are folks all over selling those things. By the time you put in the older cluster and all of the cable, you might have saved some money, but you will have gone back in time to do so.
Yes, it's an N/A. It IS a 3.0 liter V6 though. Does that matter?
MitchB is offline   Reply With Quote
Old 06-26-2005, 01:37 AM   #6 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
yeah it is a basic plug in (the cable is a bit tricky, but youll get it)... the rest are just wire clips that snap into place.
Function over form.
Drifting Dane is offline   Reply With Quote
