Low Idle? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-18-2005, 09:14 PM   #1 (permalink)
View Diff Operator's Photo Gallery
Question Low Idle?
Last night, my 93 MR2 turbo started idleing lower than it's normal 800 or so rpm. I read a post where someone had the same problem. I just bought the car and already ordered tune up parts. I heard about two afm screws, where exactly are these and how should I adjust them? should I clean the throttle body? Thanks!
Diff Operator is offline   Reply With Quote
Old 06-19-2005, 12:08 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
the screws are located on the AFM where the wire plug is connected to AFM...But you shouldn't mess with the AFM screws..I would wait till after you tune her up before doing anything else. that may be the only cause of the low idle...did you order plug wires too?
The Jedi Speeder at CarDomain
Old 06-19-2005, 09:14 AM   #3 (permalink)
Yep, sure did. So do you thimk I should use some tb cleaner on the AFM do you? -Thanks!
Old 06-19-2005, 11:32 AM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
as for the TB cleaner-I don't know. I had thought about doing it too, just to know that everything was was clean, but I'm not sure what effect(if any) it would have passing thru the turbo..that in tiself would probably be an interesting thread....I would try the tune up and see where that puts you before you do anything else...
Old 06-25-2005, 07:13 PM   #5 (permalink)
View MitchB's Photo Gallery
Unplug the three-wire connector to the ISC, which is located under the throttle body. The idle should go up. If not, the ISC (Idle Speed Control) is gummed up.
Do NOT wash out the TB with a flush of cleaner. That procedure, although popular, is a BAD idea, as it washes the gunk down into the ISC, which is a small valve, and freezes it up once it's dry.
If removing the plug does not change the idle, you likely have a stuck ISC. To clean it, you should remove the TB and then remove the ISC from the TB with an impact driver like they use on motorcyles to remove the phillips head screws.
Yes, it's an N/A. It IS a 3.0 liter V6 though. Does that matter?
MitchB is offline   Reply With Quote
Old 06-27-2005, 11:21 AM   #6 (permalink)
Wazzuup!
MR2crazybyong's Avatar
View MR2crazybyong's Photo Gallery
i had the same problem.. what i did was, i took off the tb and to find it full of grim.. so i took everything apart and cleaned it.. especially the ISC... then i put it back together, started the engine, wait for it to warm up to operating temperature then adjusted the idle.
www.cardomain.com/id/mr2crazybyong
YM id: mr2crazybyong
MR2crazybyong is offline   Reply With Quote
Old 06-28-2005, 01:43 PM   #7 (permalink)
Idles okay once warmed up?
So I changed the rotor, cap, plugs, and wires. The car drives much better, especially top end acceleration. Unfortunately, for the first minute or so I'm in the car (before it warms up), the car will still idle low. Any ideas?
Old 06-28-2005, 02:02 PM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
is this a turbo or N/A?
Old 06-28-2005, 02:19 PM   #9 (permalink)
Turbo!
Old 06-28-2005, 03:20 PM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I believe there should be a valve type device that suppose to keep your rpm's high on start up until engine warms up..that maybe malfunctioning
Old 06-28-2005, 03:24 PM   #11 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
possibly his cold start injector malfunctioning... or the sensor feeding the info?
or do the turbo models even have those???
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 06-28-2005, 08:21 PM   #12 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I beleive it does and thats what I'm talking about..mine will idle at about 1200rpm until running temp is reached.
Old 07-02-2005, 07:12 PM   #13 (permalink)
Yeah, you could do what I said in the earlier post.
