mannnnnnnnnnnnnnnnnnnnn - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-22-2005, 09:36 PM   #1 (permalink)
View blazin_azn's Photo Gallery
Angry mannnnnnnnnnnnnnnnnnnnn
like last time my car died on me...i needed to push start it
everytime i turned the key i would just hear a "clack"
ok...after i push started it ...it worked again......i turned it off and turned it back on..it worked
please guys...tell me wats wrong...b/c this is embarassing
lol
91 MR2 NA ( NA for now)
blazin_azn is offline   Reply With Quote
Old 06-22-2005, 09:38 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
1) Clean battery post terminals with a brush and water+baking soda EVEN IF THEY LOOK GOOD
2) Test the battery
3) Replace the starter, the solenoid is more than likely shot
4) Replace alt.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 06-22-2005, 09:46 PM   #3 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
I just went through the exact same thing.... I had to constantly rough uo my terminals to get a good conection... eventually that didn't even work. last weekend it wouldn't start.. I messed with the terminals, still nothing... so I got a jump-start from the work truck... fired up... but then i turned the wheel.. and the voltage dropped and killed the car. so I got another boost. drove home carefully... and swapped the battery from my subaru (new battery) into the duece.... works great! hasn't happened since. I still thougt my battery was good... but apparently not. get that checked out.. or, if you KNOW it's good (already tested it) pull the starter and test it manually... supply power to it, and see if it extends and turns.. and then retracts...
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 06-23-2005, 01:19 AM   #4 (permalink)
no more V-6...
from what you're describing I'd say it's either your battery, or the connection to the battery....
back to the 4cyl...
Old 06-23-2005, 12:20 PM   #5 (permalink)
hmmmmmm
sorry guys...i dunno what your guys mean by terminal
help.
haha
Old 06-23-2005, 12:25 PM   #6 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
the + and - connections
BlueFusion6851 is offline   Reply With Quote
Old 06-23-2005, 01:17 PM   #7 (permalink)
View keck03's Photo Gallery
i had a similar problem but i was just being an idiot. i didnt make sure the terminal was shielded from the spare sitting on top (that little protective thing was pushed to the side). the tire was then touching both the + and the -
keck03 is offline   Reply With Quote
Old 06-23-2005, 01:26 PM   #8 (permalink)
i don't have a spare tire nor the protector
any other suggestions?
Old 06-23-2005, 03:16 PM   #9 (permalink)
what is the best way to clean my terminals ? and without shocking myself ?
Old 06-23-2005, 04:24 PM   #10 (permalink)
like when turn the key all my lights and head unit turns on including the mr2 clock. when i turn it for it to start....that clock starts to fade
arghhhhhhhhhhhhhh WTF IS WRONG>!?!?!?!
hhahahahah
Old 06-23-2005, 06:17 PM   #11 (permalink)
no more V-6...
yeah... I'd say time for a new battery... especially if the lights are dimming when you turn it on... does your "buzzer" sound pansy style when the door is open and you insert the key into the ignition??
back to the 4cyl...
Old 06-23-2005, 06:46 PM   #12 (permalink)
Rocket Surgeon
woody's Avatar
View woody's Photo Gallery
best bet is the starter, the solenoid sounds hooped. Next time it dies, don't push start it, just beat the starter with a hammer a couple of times. If it starts right away afterward, the starter is worn out. They usually come to rest on one of 3 points after every time you fire it, these points then get worn over time and a slight jarring, like the hammer, will move it slightly and get the brushes connecting again. Or get the solenoid to free up.
woody is offline   Reply With Quote
Old 06-23-2005, 08:26 PM   #13 (permalink)
well...i went to autozone..they checked my battery they say "its fine"
and it happened there again!!! my gauges were blinking...and it wouldn't start.
he hit the starter a few times and it wouldn't start still.
we had to push start it.
whats the solenoid? and how do i test it if its messed up?
