Fuel Cut - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2005, 01:15 AM   #1 (permalink)
View DR.2's Photo Gallery
Fuel Cut
Is there a easy way to by pass the fuel cut. i know there is a system you can build that fools the computer into thinking its running 12 pounds but it seems complicated.
DR.2 is offline   Reply With Quote
Old 06-27-2005, 04:45 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
If you cork the vac the line to the MAP sensor you will eliminate fuel cut 100%.
This also stops your OEM boost gauge from working (not that that thing has any value anyway).
If you build the fuel cut defencer, that raises fuel cut.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
