lights in the cluster
today i was installing a replacement antenna frm metra/antennaworks i dont recomend anyone buy this antenna as a replacement stick with oem b/c its a B**ch to install as it doesnt fit flush.. i drained my battery b/c i left the key turned to ignition as i was messing around with the radio to try to raise and lower the antenna mass to see if it was working. i connected a battery charger to my battery and i let it charge for about 20 min. so i turned on my car as it was charging and when all the lights in the cluster went off 2 lights stayed on the ABS and the little engine icon. later in the night i went to drive and get gas and my mr2 went about a 1/4 mile down the road and i noticed the headlights turn dim and the radio lights go dim as well as the gauge cluster lights and then the car started to sputter and then it died. it was because of a dead battery. im just currious does the ABS light come on when the battery voltage is low because it has never come on before for me and the engine icon to the lower rights handside of the gauge cluster is on. could that be because of the battery voltage or because the alternator is done.
really need answer for this ASAP
Thanks
Sean
If it's cheap and fast, it's not reliable
If it's reliable and cheap, it's not fast
If it's fast and reliable, it's not cheap
VTEC: All the lag, none of the turbo. It's like waiting for bad sex! ...
