anyone TRIED to change ball joints?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-27-2005, 11:12 PM   #1 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
CRAP!! I broke three ball joint removal tools trying to remove one (count'em.. 1, uno, singular)
front ball joint... the mother just wouldn't budge!! I soaked it in penetrating lube.... still standing strong!! I gave it a few "taps" with a micro adjustment tool (hammer).. .. that didn't help any either??!?
anyone else tried to replace them yourself?
I'd go ahead and say it's a do-it-yourself type thing.. but geeze... mine won't budge...
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 06-27-2005, 11:28 PM   #2 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
what kind of balljoint removal tools are you talking about here? I have a fork-shaped tool that I use and I've never had a problem, on lots of cars.
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 06-28-2005, 12:17 AM   #3 (permalink)
no more V-6...
the style I was using was "designed" sort of like a pulley removal tool...
it has two L-shaped "legs" that are hinged and are supposed to hold on to the lower control are, while the main bolt of the tool is tightened to push the ball joint loose from the control arm...
I've bent two, and broken one.
I havn't used the fork style simply cause my service manual call for the other design.
back to the 4cyl...
Old 06-28-2005, 12:32 AM   #4 (permalink)
The Mad Scientist
Those suck, get the badass fork type and a big hammer.
Old 06-28-2005, 04:07 AM   #5 (permalink)
no more V-6...
but if I use the fork style.. won't it damage the rubber skin surrounding the ball joint?
back to the 4cyl...
Old 06-28-2005, 04:30 AM   #6 (permalink)
The Mad Scientist
Probably, but at least you'll get it apart!
Old 06-28-2005, 06:27 AM   #7 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
If your changing the balljoint what difference does it make if the rubber boot gets damaged? The new joint should come with a new boot.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 06-28-2005, 01:34 PM   #8 (permalink)
no more V-6...
you know... I realized this ^^^ about 8am... when I woke up...
what the hell, beat it to death, I've got new one's!!!
back to the 4cyl...
Old 06-29-2005, 11:54 AM   #9 (permalink)
resurector
View leiniesred's Photo Gallery
ball joint trick
The Bashing isn't where you would expect. Bash the casting around the ball joint stud. I mean hit it like you mean it. It won't break.
Tighten your ball joint puller a little. Bash some more, tighten a little, bash some more. hey wow, I can tighten the puller again, bash some more. POP! it'll come out.
leiniesred is offline   Reply With Quote
Old 06-29-2005, 01:37 PM   #10 (permalink)
no more V-6...
as much as I wanted to kill that casting... I just couldn't bring myself to hit the car any harder.... but it's got it coming this weekend.
back to the 4cyl...
Old 06-30-2005, 11:53 PM   #11 (permalink)
no more V-6...
my car is the DEVIL!!!! It broke the forked ball joint removal tool this afternoon!!!!
I'm taking everyone's advice in... beating the crap out of this thing to remove the part..... spray it with penetrating lube.... wail on it some more... and ""cling"".... the aluminum fork just snapped! broke one side of the fork off!!??? so.... maybe my ball joints ARE good.... but not after what I've put them through!!!
I'm gonna go buy another one... and see if I can feed more tools to my car.
back to the 4cyl...
Old 07-01-2005, 06:56 AM   #12 (permalink)
View 91MR2quickNA's Photo Gallery
LOL!
Try a heavy dead blow hammer. I had the same issues when I did my outer tie rods. Grr.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 07-02-2005, 07:08 PM   #13 (permalink)
View MitchB's Photo Gallery
Note, there are TWO sizes of pickle fork tools: one is typically used on tierod ends, the other on American-car-sized balljoints. The large tool is the one you need to span the tapered stud of the balljoint. My guess is, the small one you used was too narrow, which is why it broke off. Some large tools, however, may be too large for the task - they do vary a bit.
I have done a LOT of MR2 balljoints with a pickle fork. Turn the steering all the way to the side you are removing and insert the fork from the front of the car near the fender. (You may want to protect the fender with cardboard or something.) Slowly tap the tool into the joint until it stops solidlly, then whack the tool pretty hard with a 3-to-5 lb. hammer.
I have yet to have one withstand this method.
Yes, it's an N/A. It IS a 3.0 liter V6 though. Does that matter?
MitchB is offline   Reply With Quote
Old 07-02-2005, 07:12 PM   #14 (permalink)
no more V-6...
thanks for the info... but the strut I ordered AGAIN... has not been delivered... and probobly won't be delivered until the 6th... reason for me saying so is, I was gonna change everything at once.... but we'll see...
thanks again for the tip.
back to the 4cyl...
Old 07-03-2005, 12:36 AM   #15 (permalink)
N/A bites
Tercel GTS's Avatar
Never heard of an aluminum ball joint fork.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
