door speaker access/replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-02-2005, 01:52 PM   #1 (permalink)
View mr2blur's Photo Gallery
What's the easiest and least destructive way to get to my door speakers of my 1991 MR2. Thanks in advance for the help!
mr2blur is offline   Reply With Quote
Old 07-02-2005, 03:22 PM   #2 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
well... the ONLY way is to remove the door panel. there are about 5 phillips head screws along the outer edge of the panel... then you'll have to remove the plastic shroud that is around the door release lever (the thing you pull to open the door from the inside).... THEN you have to pull upwards like a mother on the door "cup"... it's where you normally would hold onto the door to pull it closed.. I use it for loose change...
then you'll have to disconnect the "push tabs" that hold the door panel to the door.. they just snap loose.... then gradually lift the door panel upwards away from the door, then pull it off.
now you can access the speakers! there are three phillips head screw holding them in place ... I think
good luck
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 07-02-2005, 07:47 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
also if you have power locks and windows have to disconnect the plugs to them.
The Jedi Speeder at CarDomain
Old 07-02-2005, 08:31 PM   #4 (permalink)
no more V-6...
ah... forgot that part...
thanks mr2bad
back to the 4cyl...
