starting problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2005, 05:38 PM   #1 (permalink)
View mr2trbo93's Photo Gallery
2nd Generation starting problems
i have a 91 n.a and its cranking over but not starting.. i was wondeering if this problem is most likely the ignition coil?? i changed the d-cap and rotor but nuthin i am ordering wires and gettin plugs and ideas of wht this is ??i was driving and all of a sudden started putting and stalled
mr2trbo93 is offline   Reply With Quote
Old 07-13-2005, 05:45 PM   #2 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
I was going to suggest a starter or solenoid until you said that it crapped out WHILE you were driving...
check the battery terminals, make em clean and tight! make sure the wires arent frayed, and be sure the bolt that holds the ground wire is on tight as well.
Function over form.
Drifting Dane is offline   Reply With Quote
