Help please!! Ignition problems!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-15-2005, 08:48 PM   #1 (permalink)
STUFF
View stgranger's Photo Gallery
Hey guys, Im having problems with my 93 NA. The car died yesterday while I was driving and wont start now. The check engine light came on shortly before and gave me code 12 which is basically ignition system problems. I have new plugs, wires, cap and rotor. Also I am not getting a spark at the plugs but I do have power at the ignition fuse. Basically I think it has to be the distributor, but I thought I would get some advice before I went out and bought one.
So what do you guys think? distributor??
thanks, scott
93 Toyota MR2, 88 Mazda RX7, 69 VW Bug
STGranger@cox.net
stgranger is offline   Reply With Quote
Old 07-15-2005, 10:10 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997075
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
are you getting fire from the igniter?
The Jedi Speeder at CarDomain
Old 07-15-2005, 10:35 PM   #3 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
the 93's 5sfe distributor has the ignitor built in... ( it's inside the distributor cap)
from what he's saying, I'd go with the ignitor\distributor...
absolutely.. power to the ignition system... power to the distributor.... no spark... = either ignitor, or distr. but just to be sure, check your rotor and cap one more time to see if they are contacting properly. ( I know you know this but still...)
good luck
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 07-15-2005, 11:49 PM   #4 (permalink)
STUFF
thanks for the input guys, I just finished changing out the distributor and it works great now. I even found out that I dont need a speed sensor anymore. I found a loose wire while I was in there fooling around.
STGranger@cox.net
Old 07-16-2005, 03:00 AM   #5 (permalink)
View mr2trbo93's Photo Gallery
may b go ahead and try ur ignition coil thats whats rong wit my 91 n.a
mr2trbo93 is offline   Reply With Quote
Old 07-16-2005, 05:47 PM   #6 (permalink)
View MitchB's Photo Gallery
For future reference, the Code 12 refers to loss of signal from the distributor during cranking.
The Start wire from the ignition switch that goes to the starter also goes to the ECU. From this signal, the ECU knows you are cranking the engine over when you turn the key, and it looks for a signal from the distributor. If no signal appears after a very short time, the ECU throws a Code 12.
Glad you fixed it so simply.
Yes, it's an N/A. It IS a 3.0 liter V6 though. Does that matter?
MitchB is offline   Reply With Quote
Old 07-16-2005, 09:34 PM   #7 (permalink)
no more V-6...
good info to know mitchB... thanks
back to the 4cyl...
