Good Question. Well the most popular intake mod for the MK1 would be the "PowerMax" setup explained here: http://www.padandwheels.com/mr2/intake/intake.htmlThis one may give you 2-5 HP depending on intake temperature (Colder the better) and filter type. I went for this first but the engine suffered from too much hot air entering the intake as the filter will be really close to the heat source of the engine with this setup. Also, it features a rain shield..bad bad idea. You will block the filter for the bonnet air vents thus even less fresh air. For months I tried to see what the best cold air intake would be for the MK1. Some people make holes (86+ MR2 MK1s come with this stock) on the firewall to the trunk and stick a air filter there, also they fabricate a custom side vent cutting the side part of the truck were the filter sits. This is a very good setup for power, especially in cold nights. I rellocated my batery to the front compartment (For room) and routed my intake close to the original 85 OEM position. The filter sits about 6 inches from the ground. It gets all the cold air and never comes in contact with engine heat because its placed way at the botom. I did this joining 3" intake pieces, one 60 and one 90 degree adapter for the bends. The car now responds better to slight throttle changes than with the stock or even the infamous powermax setup.
