Clutch question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-18-2005, 07:31 AM   #1 (permalink)
F1 freak!
View Silver-Arrowz's Photo Gallery
Clutch question
The car is a gen 2 with a 3SGE motor. I know it's lacking in power but when I was at the track I decided to have a go at smoking the rear tires up. So 7000rpm, 1st gear, drop clutch....... but nothing happening with the rear wheel. I was smoking the clutch instead.
I was thinking the clutch needs replacing but when driving on the circuit and on a daily basis, the clutch seems fine. Absolutly no sign of slipping.
Is the clutch worn? Or is it just cheap clutch inside? Could it be something else?
I don't suffer insanity, I enjoy every minute of it.
Silver-Arrowz is offline   Reply With Quote
Old 07-18-2005, 08:00 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Clutches can only hold so much torque and as they wear that amount gets lesser and lesser.
Chances are you clutch either can't hold the torque for a 7000 rpm clutch-dump or your clutch is starting to ever so slightly that it no longer can hold that much torque.
Apparently the other driving you do is well below what the clutch can hold (still hold) so you are not having problems there.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 07-18-2005, 05:34 PM   #3 (permalink)
BahaMR2
numbone's Avatar
View numbone's Photo Gallery
do clutches get so hot that their performance declines jeff?
1992 GT-S
numbone is offline   Reply With Quote
Old 07-18-2005, 06:19 PM   #4 (permalink)
I love Cin
Yes, you can piss off a clutch.
In all reality you should not, but you can.
A healthy clutch should not get "too hot" to hold torque, but a clutch that is wearing can.
Keep in mind the difference between a clutch and a brake.
Brakes work because they change kinetic engery (moving stuff) into heat.
There is a limit to how much heat they can absorb and vent.
A clutches job is to trasnfer kinetic energy from one place to the nextso "heat" should not be part of the equation.
Old 07-18-2005, 06:55 PM   #5 (permalink)
All Function
View anarkia1ces's Photo Gallery
Too much torque exceeds clutch specs... Or, the problem is between the wheel and the seat . Try a lower RPM.
anarkia1ces is offline   Reply With Quote
