annoyin boost problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-21-2005, 04:24 PM   #1 (permalink)
View danboy's Photo Gallery
Angry annoyin boost problem
has any1 had this problem?or one similar?
at low boost,bout 4psi,my car runs ok,but hesitats just slightly under load,but when i have the boost higher,it realy hesitates and jerks badly,and will barely boost above 11psi,when i hav it set to a bar.It used to boost to a bar in 5th,but only to bout 8psi in lower gears,which i couldnt understand?i have a ball and spring manuel boost adjuster on it but i dont entirely trust that.iv checked the maf meter,it gives out the corrct readings,and so does the iat sensor.does any1 have any sujestions or ideas as to what may be wrong?? thanks
danboy is offline   Reply With Quote
Old 07-21-2005, 04:39 PM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
how old are u ignition components???....i would suggest changing your cap/rotor/wires and plugs and see if hesitation continues.....nine times out of ten....its ignition related.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 07-21-2005, 06:12 PM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
When you say you "checked the maf meter," I hope you did not undo the 2 tiny screws on the side of it. That would damage the unit.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 07-21-2005, 11:52 PM   #4 (permalink)
Not even Noob
View Ratfink's Photo Gallery
I know I am new here and sad to say I don't have my MR2 yet, but wont a BOV do this too? If the preasure is not released would it not do the same?
Ratfink is offline   Reply With Quote
Old 07-22-2005, 07:55 AM   #5 (permalink)
I love Cin
A BOV could be the problem if it is opening prematurely and letting the boost out so it does not build.
Old 07-23-2005, 08:00 AM   #6 (permalink)
i did have that problem with my HKS BOV,but i lil doctoring cured that!
I also had an alternator problem,so had it repaired,and that seems to have made a large difference,but you can still feel the hesistation slightly,so i might have to go with the ht circuit.any recomendations on whos leads and cap etc to use?im from england and toyota bits over here cost fortunes!
