is it real - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2005, 04:43 AM   #1 (permalink)
View 91RED3S's Photo Gallery
is it real
how do i tell if the "jdm" engine and tranny that i am getting really is a JDM 2nd gen engine?
91RED3S is offline   Reply With Quote
Old 07-30-2005, 06:16 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
There isn't realy any difference in the Gen IIs, so why bother with a JDM engine?
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 07-30-2005, 12:03 PM   #3 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
The ecu is different, but not cosmetically... the only way to tell is to hook it up to a dyno and get a stock pony run, then compare that to the US spec stock power.
Or, just trust the guy thats doing your swap
Function over form.
Drifting Dane is offline   Reply With Quote
Old 08-01-2005, 03:28 AM   #4 (permalink)
fortunatly im the guy doing my swap, and the reason i went jdm is because i dont have a local supplier for the 3sgte and i dont have the money for a new engine or to rebuild mine. will i notice any power difference between usdm and jdm if i use my ecu, i have to use my ecu
Old 08-01-2005, 12:28 PM   #5 (permalink)
Boosting 15 psi :)
the usdm (or jem, i dont know which it actually is but it doesnt really matter for this discussion) engine's ecu is tuned differently than the jdm one.
the jdm ecu upped the boost i think two psi and tuned at that boost level, if you use the us-spec ecu, you will loose 25 hp to the flywheel, or maybe about 10-15 to the wheels (nothing a boost controller cant fix )
Function over form.
Old 08-01-2005, 01:39 PM   #6 (permalink)
I love Cin
The JDM ECU is more aggressive because they have a higher octane fuels and can use the more agrgressive A/Fs & timing. That is not something that will change with a boost controller.
I'm not sure the actual boost levels were different on the Gen IIs.
I know the Gen IIIs offered more boost.
Old 08-04-2005, 11:11 PM   #7 (permalink)
well i got the engine finally and it is ready to be dropped in, i gotta say, the damn thing better run good, because it looks like shit, i mean this thing is filthy on the outside, its good and clean inside the intercooler pipes and intake though, i'll have more info tomorrow when i get the thing running
Old 08-05-2005, 05:11 AM   #8 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
91 RED3S : if you don't mind me asking... where did you get your engine?
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
